October 24, 2005, 07:10 |
Error reading msh file into Fluent
Hi folks,
I have generated a large 3D grid in Gambit (ab. 1,000,000 cells) and now I am trying to read it into Fluent. But Fluent refused and gave following error: > reading geometrie.msh ... ............ ............ ............ 999999: MPT_csend_int: error: file = section.c, line = 6251: mpid = 0 undefined: Operation would block 999999: MPT_csend_int: error: file = section.c, line = 6263: mpid = 0 undefined: Operation would block sh: syntax error at line 1: `(´ unexpected What the h… does that mean?? After that, Fluent has to be killed and restarted again ... Any help is highly appreciated! Ralf |
October 24, 2005, 07:26 |
Re: Error reading msh file into Fluent
re build your mesh file whith low mesh and try again
October 25, 2005, 10:56 |
still error reading msh file into Fluent
now I was using 10 as a grid size (instead of 8) to minimize my mesh. So Fluent begins to read the mesh... but while reading BC, following error appears: Dump usage: 1141627 cells, 2446863 faces, 274585 nodes this is repeated very often (with different values for faces and nodes) and nothing happens... what is the Problem?? |
October 25, 2005, 17:02 |
Re: still error reading msh file into Fluent
increase RAM of ur system
October 29, 2005, 02:25 |
1- increase RAM of your system 2- when you read mesh file choose segregated solver
October 30, 2005, 20:00 |
there are some problems with the mesh reading when you do it into parallel mode. But i have observed that if you can read the mesh first into single processor and do the manual partioning and then save the case data files. And then read into fluent parallel it reads okey. I in start got some errors like you have mentioned but then i started doing manual partioning and then there is no probs till now.
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
Making msh file for Fluent | Jack | FLUENT | 1 | January 9, 2007 09:17 |
