import *cas file from fluent to gambit??
Old   October 23, 2005, 23:58
Default import *cas file from fluent to gambit??
Rashmi
hi all cn anyone tell me how do i import the *cas file from fluent to gambit...my model is a simple 3d pipe..what all specification or data i hav to provide b4 i export the file from gambit and b4 i import the file from fluent...
thanks in advance
Rashmi
Old   October 24, 2005, 09:57
Default Re: import *cas file from fluent to gambit??
pUl|
A normal procedure is to create the geometry in gambit, mesh it appropriately, specify the boundaries and their types (i.e. velocity inlet, wall etc.) and export the mesh in Fluent 5/6 format (*.msh). This is followed by reading the mesh into the Fluent after specifying the nature of the solver (i.e. 2d/2ddp/3d/3ddp etc.).
Now, what was your question again?
Old   October 25, 2005, 01:50
Rashmi
ok listen..
i have to create a structured meshed pipe a simple pipe..so if i create the cylinder directly and then mesh it it is nt structured...ie i cannot mesh the volume of the pipe using map scheme... so i created the geometry by edge and face split method ie dividing the origional volume into many volume and meshing the seperate volumes by map scheme.....but i want a single meshed volume for that we have to mesh all the volumes and thn export the file as *msh file n thn open in fluent and save as cas file and thn import the cas file into the gambit u gt a single meshed file........this was suggested by some one ...i tried the same but could not import it...getting error....so if u knw hw to do it exactly plz explain
thanks Rashmi
Old   October 25, 2005, 01:56
pUl|
If you use a boundary layer, you can get a very nice resolution starting from the wall and becoming coarse as the centerline is approached. There will of course be a certain region in the center which will be devoid of any control volumes. So to take care of that, you can use either a quad (map or submap) or a quad (pave) scheme to mesh the entire volume; although the former is recommended. This way, the mesh will be well controlled from the wall upto the center. Please give it (boundary layer) a try and let me know.
Old   October 25, 2005, 02:10
Rashmi
u r saying giving boundary layer to the unstructured meshed volume...no but cn we use guad(map or submap)to mesh the volume..i hav tried several times but we cannot mesh it using map..we hav to use cooper scheme...
Old   October 25, 2005, 02:18
pUl|
Check your email in the next 5 minutes.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
