Gambit Step Files Import
Old   October 22, 2005, 00:25
Default Gambit Step Files Import
dg
I am trying to import a step file into gambit and I get the message ACIS error 1015 : Access violation....any thoughts
Old   October 22, 2005, 17:39
Default Re: Gambit Step Files Import
James
Try IGES.
James
Old   October 24, 2005, 16:10
Freeman
I suggest you the same, 'cause I got the same problem sometimes and I solved it by this way
Old   October 25, 2005, 22:15
dg
Ok....I think I found the problem, I noticed that I was able to load step files with shorter file names, so I shortened the file name and took out the _ in the file name and I was then able to import the step file that I was having problems with earlier....a strange solution, but it worked
[Commercial meshers] Import of Multi-Region Mesh from Gambit with non-conformal interfaces sebonator OpenFOAM Meshing & Mesh Conversion 18 June 25, 2014 12:09
Gambit import pb jimi Main CFD Forum 0 October 26, 2009 08:11
problems with STEP file ertan FLUENT 0 August 1, 2008 18:51
Import of gambit db files worth Siemens 2 September 24, 2004 06:52
best step import in gambit ? Charles Renard FLUENT 0 June 29, 2001 04:15
