October 20, 2005, 10:24 |
Convert Real edges to Virtual in Gambit
Hi all!
I've got a little question using Gambit. I know that there is an option to convert virtual edges into real ones but is there any way to make the inverse step, i mean, to convert real edges into virtual?? Thanxs in advance. |
October 20, 2005, 11:01 |
Re: Convert Real edges to Virtual in Gambit
Can i ask why you'd want to? You can create virtual faces/volumes from real edges, so there's no real need to. Whereas there is some merit in converting a virtual edge to a real one.
Kind regards, |
October 20, 2005, 16:35 |
Thanxs Dan for your interest Dan.
Well, I will explain you the whole issue. I have a 2D drawing that I'd successfully imported to Gambit as a .sat file. In order to make a mesh as I want, I create little faces (subfaces) that divides 2D domain: these subfaces are made from virtual edges that I draw first with Gambit's tools. The fact is that it is much more comfortable for me to draw geometry in AutoCAD and then import it into Gambit than to create geometry with Gambit's tools. It would be nice to draw these subfaces' edges in AutoCAD and then, make them virtual in Gambit (because all geometry imported is real and I need these edges to be virtual, as they are only a way to create and mesh these subfaces, and I don't want them (edges) to appear in Fluent). I don't know if that above has been as clear as I wanted :S Is there any tool that makes so? |
October 21, 2005, 04:14 |
As long as you divide your surface into subfaces with internal edges that are connected (not overlapping), these edges will be set by default as interior by gambit when writing the mesh and they won't appear in Fluent.
Hope this helps Edi. |
October 21, 2005, 15:35 |
Thanks edi!
But these internal edges you are talking about are real or virtual? I think I don't understand you when you say "internal edges", what do you mean? I've tried drawing the edges in autoCAD (with the rest of the geometry), importing it to Gambit, creating and meshing the subfaces with these edges and when I make the mesh file and open it with Fluent, these edges appear... Your method is similar to this? Thanks a lot! |
October 24, 2005, 05:37 |
The edges I was talking about are real. By internal edges I mean edges that are not at the boundary, i.e. they are shared between 2 subfaces (I don't know if I make myself clear).
It seems to me that your so called "internal edges" are not connected, so when you read your mesh into fluent they are set as walls. Check in gambit if these edges are connected, since when you import some models from cad packages they usually aren't. Hope this can help Edi. |
October 24, 2005, 15:14 |
That was the point.
I've just tried to draw all the geometry in AutoCAD, imported it to Gambit and when the mesh was done and imported to Fluent, those edges simply dissapear as you said. Many thanx eddie, that was very helpfull! |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
convert to real in gambit | mutena24 | FLUENT | 7 | January 11, 2010 03:13 |
[GAMBIT] Difference between real & virtual line, face, & volume?? | teguhtf | ANSYS Meshing & Geometry | 2 | October 5, 2009 07:47 |
virtual or real flow volume for wind tunnel? | qm | FLUENT | 1 | January 9, 2009 15:26 |
GAMBIT and Turbomachinery | tom | Main CFD Forum | 6 | October 21, 1999 09:50 |
