October 19, 2005, 12:47 |
Error in fluent:iter continuity
Hello all, I have this problem:every time i start fluent6 to iterate i get this error msg: iter continuity x-velocity y-velocity time/iter
Error: This is a post-processing only executable. Error Object: () could somebody tell me why does it happen? thank you very much in advance |
October 19, 2005, 13:43 |
Re: Error in fluent:iter continuity
you only have a post processor part of FLUENT open. Its used for processing results.
The iterative solver is unavailable in this version. Either you dont have a license for the solver or you are starting FLUENT with wrong arguments in command line. Type fluent in the run dialog box in start menu and see if that works |
October 20, 2005, 05:11 |
thank you very much, the problem was what you sáid..i din't have any lisense thanks again
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
