How to find Mach Number
Old   October 18, 2005, 04:53
Default How to find Mach Number
Tobias
Hello, maybe somebody is able to help me with the following problem. Under velocity does not appear Mach Number. Do I have to define Mach Number by myself (custom field function ?)
Thanks Tobias
Old   October 18, 2005, 05:35
Default Re: How to find Mach Number
Dan
Hi, Mach number will appear in the velocity contours if you run the problem with an ideal gas. (materials panel-density). Hope that helps.
Old   October 18, 2005, 10:59
Tobias
Hello dan, thanks. Your tip helped me a lot (now Mach number appears). Thank to you Tobias.
mach number and selection of the fluent solver turbinesv FLUENT 4 April 24, 2011 01:14
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Mach number in Post processor Ramu Maddi CFX 3 August 17, 2007 11:06
The Far-field Pressure Boundary & Low Mach Number Saif-Deen Akanni FLUENT 1 March 5, 2007 06:05
how calculate the density in low mach number? Juhee Lee Main CFD Forum 1 July 31, 1999 16:26
