multiphase mixing Problem with MRF model in MixSim
Old   October 17, 2005, 07:35
Default multiphase mixing Problem with MRF model in MixSim
Srinivas
hi all
I am Srinivasa T, a postgraduate student from IITMadras, doing my project. My project is as follows:
A open mixing tank fitted with internal helical coil and a stirror/impeller, with some volume fraction of solid particle of given dia(micro meters). no inlet and outlets to tank.
Problem Description:
My project is to study the effect of internal helical coils on solid suspension in mixing tanks/sparged vessels. I am using "Multiple refence plane"(MRF) model for impeller and "Eulerian Granular model" as multiphase model and "Standard k-epsolon model" for turbulence. Iam using "MixSim 2.o" provided by FLUENT Inc.for simulation.
Problem I am facing:
I am confused what are all the boundary conditions should i give for this problem when i shift to FLUENT after geometry construction and meshing in MixSim. So i need your help in this regard. Kindly suugest me how can i define boundary conditions for this problem.
thanking you,
your sincerely, Srinivasa T M-Tech (Chemical Engineering) IIT Madras Chennai.
Mixing model with rotating impeller problem 201 CFX 10 May 14, 2010 12:59
Air & water mixing problem praveenkumar FLUENT 0 April 15, 2010 03:14
multiphase model, water in air? bugra Main CFD Forum 10 January 2, 2010 14:09
problem in using MRF model haamed Main CFD Forum 0 October 12, 2009 09:45
mass balance problem in multiphase model mdsanij1 FLUENT 0 July 28, 2009 17:01
