fluent: residuals
Old   October 14, 2005, 10:49
Default fluent: residuals
Madhukar Rapaka
Hi all
is there any process to view the residuals for a particular domain. i mean if one starts a simulation choosing "plot" residuals option, fluent plots the residuals for the complete geometry. Is it possible to plot the residuals for a particular region, where some deviation starts. if in the simulation something went wrong how to know where the problem exists.
anysort of help is highly appreciated
thanks in advance
Old   October 14, 2005, 11:28
Default Re: fluent: residuals
Thérèse
Hi, u can create a point or surface in some particular zone in your domain, like the wake of a cylinder for example where the flow is complex, then plot or store the evolution of velocity or other variables in that particular location while the model is running. You can do so by increasing the number of surface monitors (in the solve-monitors-surface panel) check out the procedure in the manual. Hope that helps!
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
The residuals in FLUENT summer FLUENT 2 June 28, 2006 10:31
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 06:45
Fluent Parallel/Serial version..jump in residuals Sandeep Abhyankar FLUENT 4 January 10, 2000 10:57
