K-e to RSM
Old   October 14, 2005, 05:20
Default K-e to RSM
venkatesh
hi everybody,
1)i am working on a complex flow domain, i have well converged results for K-e model. RSM was unstable if start directly with it. As per fluent manual i started with K-e and changed to RSM after few hunderd iterations now i have Turbulent viscocity ratio going above 10^5 in some cell, and residual plot vibrates a lot particularly epsilon. will this affect the results. URF is low as specified in the manual. or can i use the well converged result of k-e for RSM.
2)i have well converged results for k-e model. when i check the fluxes (mass flow rate) at inlet and outlet for my domain i have 3 cases 1) exactly zero 2) positive 10^-6 3) negative 10^-6 can anybody explain all the 3 cases particularly third case(how it can be negative?) which one would be best expected one?
thanks venkatesh
BSL RSM or SSG RSM Far CFX 15 March 20, 2014 22:34
Incompressible, Low Re RSM ivan_cozza OpenFOAM Running, Solving & CFD 0 June 9, 2009 06:08
RSM model Eric Wang CFX 1 January 7, 2009 09:55
about RSM and k-'3' (sorry cant type it) models Hao FLUENT 0 April 28, 2008 10:14
RSM divergence Steve FLUENT 2 September 28, 2004 16:36
