Change directory
Old   October 9, 2005, 11:36
Default Change directory
Nikhil
Can anyone tell me how to change to a directory which has spaces in its name through batch mode. The usual technique of including the name in the quotes (the way it is done in linux/unix) does not seem to work. Bye
Nikhil
Old   October 11, 2005, 07:51
Default Re: Change directory
Vinod Dhiman
Hi
You are using Windows. If it is Windows XP, then it should not pose any problem since you can write the full name after the command. If it is not working, as Windows is not consistent, then give command
dir /x
It will show you the abbreviated names. Use those names for changing directories.
Vinod Dhiman
Thermal phase change model Piti CFX 1 January 14, 2021 11:03
Gambit Default Working Directory Virgil Howardson FLUENT 5 December 19, 2009 07:13
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Gerris software installation mer Main CFD Forum 2 November 12, 2005 09:50
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
