Divergence detected in AMG Solver:TEMPERATURE |
November 19, 2016, 10:05 |
#21 |
abhijeet jaiswal
Rep Power: 10 |
sorry bro....i am not understand your problem....so please define it clearly....
November 19, 2016, 10:07 |
#22 | |
abhijeet jaiswal
Rep Power: 10 |
November 19, 2016, 10:15 |
#23 | |
yes
Rep Power: 10 |
l work on the three dimensional computational fluidic dynamics modeling of PEM fuel cell I study the effect of the inlet pressure on the current density.and to draw the polarisation curve of fuel cell it should show the relation between the Vcell and current my work is normally it work very good but I have problem in Vcell=0,6 the current density deacrease a lot and after that it work normally I mean why the current density fall and deacrese a lot in V cell =0. is the work correct and it work normally or the is a mistake thank you |
November 19, 2016, 10:21 |
#24 | |
abhijeet jaiswal
Rep Power: 10 |
November 19, 2016, 11:16 |
#25 |
yes
Rep Power: 10 |
November 22, 2016, 09:18 |
#26 |
abhijeet jaiswal
Rep Power: 10 |
March 11, 2017, 03:20 |
#27 |
Rajendra Singh
Rep Power: 11 |
First, you should check your mesh. If the mesh is bad or ratio is too high, the solution will be divergent and you will get AMG error.
March 11, 2017, 10:13 |
#28 |
yes
Rep Power: 10 |
the mesh is Good and all the parameters are perfect
Sent from my SM-J700H using CFD Online Forum mobile app |
July 3, 2017, 23:56 |
#29 |
Hey abir, how is it going?. I have had the same issue with amg solver: w-swirl. It does not matter how your mesh is but a little fine should be good enough. I have a question for you, how are you importing you geometry for analysis ?.
January 20, 2018, 13:37 |
Under relaxation Factor in Fluent
#30 |
Hells Blade
Rep Power: 9 |
On what basis does one decide to reduce the value of which URF in Fluent for eg when using k epsilon should i resude trubulence or the dissipation rate or another parameter or the value of the equation which is diverging in the residuals .
Also how does this affect my results |
March 15, 2018, 02:37 |
#31 |
Vignesh Lakshmanan
Rep Power: 10 |
Hi Everyone,
First of all sorry for restarting the thread. I am working with simulation of air flow through an airconditioning outdoor unit panel, with condenser coil. Fan I have modelled using MRF. My mesh size is 4,000,000 cells and 0.97 skewness. My aim is to estimate the airflow (CFM) delivered by the fan. The problem works fine. I got result matching within 5% wrt experiments. The problem is, while running, I initially ran the problem in Fluent -13 using standard initilaization and the case completed. But, if I run the same case in Fluent-17 , I get AMG solver divergence: Temperature in the first iteration itself. But if I run in Fluent -17 using Hybrid initialisation, the case runs. Could someone explain what is the problem with Fluent -17?? Thanks |
April 22, 2018, 06:44 |
#32 | |
Daniel
Rep Power: 9 |
I am having a similar problem with the choice of the multigrid cycle. Please, why changing the multigrid cycle for pressure from "V" to "W" for the 3D ROTATING/ SWIRL flow inside the pipe? |
April 25, 2018, 07:17 |
AMG Solver Divergence: Temperature
#33 |
Rajan Bhandari
Rep Power: 9 |
When I used inlet BC's as velocity-inlet and outlet BC's as pressure outlet, no error takes place. But when I changed outlet BC's to velocity-inlet, the divergence error occured. Why is that so?
April 25, 2018, 07:52 |
#34 |
Vignesh Lakshmanan
Rep Power: 10 |
Are you sure you changed the outlet boundary condition to velocity intlet??? If ya, then obviously it will diverge because you had given an inlet at the outlet.
May 9, 2018, 02:58 |
About the convergence of VAWT residual.
#35 |
Inderjeet Singh
Hello everyone, I am working vertical axis wind turbine. I have designed fine 2d model in SW and now trying analyse it's flow analysis. But I am facing convergence problem from many days. My solution residual is not going down to 10-3. My meshing skewness ratio 0.83, orthogonal quality 1., aspect ratio 93.
Divergence detected in AMG solver: ads-0 | Patrino | FLUENT | 6 | May 12, 2022 04:11 |
Error: Divergence detected in AMG solver | siri | FLUENT | 8 | March 12, 2018 18:08 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 12:34 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
