discrete model problem (water droplet evaporation) |
October 1, 2005, 13:27 |
Could anybody help me regarding the following problem?
I am simulating water droplet evaporation in a horizontal air pipe flow. Without droplet injections, the flow has a uniform 2 m/s velocity parallel to the axial direction of the pipe. The case is inviscid. When I model particle evaporation, I use coupled implicit steady solver, flow solution per DPM iteration is set to 1, underrelax for DPM sources is 0.01. I set appropriate particle diameter and mass flow for injection. The problem is that if I set the diameter above a certain value (10e-6), particles burst through the whole pipe without any sign of heat or mass exchange with the bulk phase (air). However, if I set the diameter lower than 10e-7, the particles evaporate right at the inlet. So my question is whether the method I use is right to track evaporation of particles or not. It seems strange to me that a 10e-6 particle does not have heat and mass transfer at all. Thanks for all responses in advance. |
October 2, 2005, 06:45 |
Re: discrete model problem (water droplet evaporat
Quote fom fluents defect data base:
"One of our customers is doing DPM simulation with rather small solid particles (d<100 nm). He found that in Fluent6.1 all the particles smaller than 100 nm just evaporated within the first cell. However, in Fluent6.0,the particles just travel through the domain fine. They are all solid inert particles. They shouldn't be evaporated. I have prepared a simple test case. I will put them in the usual bug area. Please try it on Fluent6.0 and 6.1. You will see completely different results. Cheers Jin" Although this bug was fixed in 6.1.23 it may be only fixed for the intert particles. Maybe it still occurs for droplets. Lots of maybes here... Have you calculated the saturation pressure for your domain? If you mixture is saturated there will be no evaporation. And 0.01 underrelax is verly low. It may take a while to see any effects. RoM |
October 2, 2005, 09:10 |
Thanks a lot for you kind answer!!!!!!!! You helped me a lot.
February 3, 2015, 07:00 |
apostolis
Rep Power: 12 |
hello to everyone,
I' modeling a solid coal combustion and i use species transport model and injection from surface. Also, i use dpm model. At injections, in particle type i have combustion. When i run the solution, at DPM iteration, it shows me "number tacked=3000, escaped=3000, evaporated=0". Is it right? Once i have combustion, i shouldn't have evaporated particles? Thank you |
October 1, 2018, 05:16 |
Water evaporation rate in water spray system
Rep Power: 8 |
Dear,
I am working on spray cooling system via fluent. I want to check water evaporation rate in my results. I want to know that what percent of water droplets are evaporated but I dont know how to check. Would you please inform me? |
evaporation of water droplet | padthai | FLUENT | 12 | June 2, 2017 10:43 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 23:04 |
CFX Liquid Evaporation Model | Jinx | CFX | 3 | January 28, 2010 17:31 |
CFX - Evaporation problem | AlessandroD | CFX | 0 | August 18, 2009 07:03 |
Converge problem of Mixture Model | Jen | FLUENT | 8 | August 17, 2005 19:23 |
