Hardware combination?
Old   September 29, 2005, 05:30
Default Hardware combination?
HP
Hi. I have a dual processor P4 2X3GHz, 2.5 GHz RAM (windows xp) and I was wondering what is the best (I mean faster!):
1)Buy one more dual processor e.g. P4 2X3.6GHz and have them (4 CPUs) work in parallel? (of course the second dual cpu PC will be using windows 32 to match the first). This case is not considered very expensive.
2)Buy one dual processor 64bit machine with linux (and fluent 64bit) and have it work alone (2 CPUs in parallel without the first dual Pentium 4)
3)Any other solution more or less with price on the same order of magnitude with the other two (or more expensive in the case that perfomance is much more increased relatively to the price)
Thanks in advance for your help.
Hardware Requirement For Francis Turbine Simulation chiragsvnit Hardware 5 January 10, 2012 01:41
Hardware for running ANSYS Fluent 12.1 ngj_22 Hardware 2 September 29, 2010 08:26
Hardware required to model sediment dynamics in rivers using SSIIM lindsaywestraadt Hardware 0 August 12, 2010 12:18
KEeping up with hardware jakaranda Hardware 1 March 13, 2010 15:02
Hardware recommendation? AMD X2, Phenom, Core2Duo, Quadcore? rparks OpenFOAM 0 April 22, 2009 10:10
