Problems at transonic flow
Old   September 26, 2005, 06:27
Default Problems at transonic flow
Mario
I simulate compressible flow through a total pressure tube at different Mach numbers. Ma=0,26...0,55 worked fine but I encounter problems at Ma=0,8. As I rise the mass flow at the inlet boundary (to hopefully reach Ma=0,8) there is a jump from Ma=0,59 to Ma=0,88 or higher. I cannot fine-tune the mass-flow to reach Ma=0,8. I use mass-flow-inlet and pressure-outlet BC. Solver settings are segregated, implicit, steady state with std.-k-eps-turbulence model and viscous heating turned on.
Any suggestions what might be wrong when trying to reach transonic flow?
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Problems with a compressible shear flow ivan_cozza OpenFOAM Running, Solving & CFD 2 May 26, 2010 11:08
Weak rotational flow - Convergence Problems Daggemann FLUENT 1 May 8, 2009 10:45
Multiphase flow convergence problems Nick CFX 1 July 12, 2007 22:18
TRANSONIC FLOW? manish mehta Main CFD Forum 1 March 24, 2005 15:03
