Gambit 2D modelling
Old   September 25, 2005, 21:46
Default Gambit 2D modelling
juliana p
there is a part in the fluent manual which says that for an axisymmetric model, we must model such that the axis of rotation is the x axis. What do you mean?
Suppose I have a conical model,must I use a coordinate system such that it is lying along the x -axis. i.e. the centerline cutting through the tip of the cone is parallel to the x axis and not the y-axis, meaning it cannot be an upright cone?
Thanks a lot for anyone who can help.
Juliana P
Old   September 26, 2005, 16:26
Default Re: Gambit 2D modelling
Evan Rosenbaum
Your understanding is correct. The centerline cutting through the tip of the cone must be parallel to the x-axis. Don't confuse the y-axis and upright. If you have any gravity-dependent physics, you can always define gravity to act in the -x direction.
Old   September 27, 2005, 10:45
Juliana P
Thanks Evan. If you happen to see this post again. Just to reiterate, so any 2Dmodel that is symmetrical about 1 axis, that axis should always be parallel to the x axis rite? Thanks again.
Old   September 27, 2005, 12:10
Jason
It has to be coincident with the x-axis (not just parallel to it). Evan's right with being able to assign a direction vector to gravity, so "upright" doesn't really have a meaning.
When you're post-processing, you can change the "up-vector" for your images so that they look more realistic. Go to Display->Views, click the "Camera" button, and here you can set the values for what you're looking at. I usually change the Projection to "orthographic". Then in the drop down next to Camera you can select "Up Vector" and define your up vector in the -g direction. In the Views panel you can also make a mirror plane (or reflect about an existing plane). Just a couple notes to help with your post-processing. It's amazing how impressed a boss can be with a pretty picture : )
Hope this helps and good luck, Jason
Old   September 28, 2005, 21:35
juliana P
thanks to Jason too!
[GAMBIT] Gambit Modelling Guide PDF PLN Prasad ANSYS Meshing & Geometry 56 August 10, 2013 07:40
airfoil trailing edge modelling in gambit morteza08 Main CFD Forum 3 June 4, 2010 14:36
Modelling a synthetic jet for a 2-d flat plate using gambit gaurav ANSYS Meshing & Geometry 0 May 1, 2009 10:59
Modelling 3D elbow in Gambit Karthik FLUENT 2 September 4, 2008 10:39
Modelling in gambit Shanti V FLUENT 2 October 6, 2005 22:55
