September 23, 2005, 03:06 |
thread facet cell in flunt
newbie here, learning the UDF, and really confued some of the terms, can some one tell me the meaning and difference of "thread", "facet" "cell", for exapmle
real x[ND_ND]; real y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x, f, thread); y = x[1]; F_PROFILE(f, thread, index) = 20. - y*y/(.0745*.0475)*20.; } end_f_loop(f, thread) in my opinion, F_CENTROID returns the x coordinate of a thread, but why let y= x[1] everytime? any hints or references would be appereciated. |
September 27, 2005, 08:02 |
Re: thread facet cell in flunt
in fluent all cells an faces are grouped together in so calles threads. as an exampel all faces that belong to a specific boundary are gouped together in one thread. lets call this thread boundary face thread and the thread number (id) can be seen in the boundary conditions panel. if you know the number of the thread you can access all faces of that thread usually with one of fluents loop macros. since the id of a thread is just a number and the thread itsefl is a data structure holding all infomations you will need to get a pointer to that data structure. there are fluent commands to do so but since your udf looks like a udf to specify a velocity profile at a boundary fluent will provide the thread pointer for you. the loop macro will loop over all faces of the boundary and face_t is just the index (id) of a specfic face. in you udf the first line uses one of fluents macros and will expand to "real x[2]" for 2d cases and "real x[3]" for 3d. this means x is a vector storing 2 or 3 components. x[0] will be the x-coodinate, x[1] the y-coordinate and x[2] the z-coordinate (3d only). F_CENTROID will store the center coordinates of a face in x and F_PROFILE will set the velocity profile for that face as a function of y. RoM |
September 27, 2005, 22:16 |
Thanks a lot, RoM, u help me a lot.
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
