Enable combustion models
Old   September 22, 2005, 13:24
Default Enable combustion models
Swarup
Dear All!
I want to use a combustion model. How do I activate it? The TUI says these models are currently "disabled". What does it mean? I tried using the particular command say: "premixed-combustion?" in the species menu.In response, I get a "Invalid Command" message. Why this is happening? Is this due to incomplete installation OR combustion models are to be activated differently? Can it be because I am not supplied with thiese models due to licensing terms i.e. they need some special license?
any advice is highly appreciated.
Thanx for all your help!
Swarup.
Old   September 23, 2005, 05:27
Default Re: Enable combustion models
Razvan
Did you enabled species transport (define\models\species\transport&reaction)?
If not, that's the source of your problem.
Razvan
Old   September 23, 2005, 08:29
Default Confusion cleared
Swarup
Thanx a lot for your suggestion. I got help from FLUENT Support team.
Swarup.
Openfoam combustion models: Kalaiselvan M Main CFD Forum 0 December 27, 2007 08:00
Different combustion models in two domains-how? tony CFX 3 October 2, 2007 14:13
Are combustion models actually any use? None given Main CFD Forum 22 September 24, 2005 12:37
Review ignition models for ICE combustion Berny Main CFD Forum 0 June 3, 2005 05:34
COMBUSTION MODELS stefano Siemens 1 May 15, 2003 08:09
