September 21, 2005, 04:52 |
periodic boundaries
I want to define two rotational periodic boundaries (the angle between them is 180°). They are identically (equal number of faces, equal geometry).
/grid/modify-zones> make-periodic Periodic zone [()] 5 Shadow zone [()] 7 Rotational periodic? (if no, translational) [yes] yes Create periodic zones? [yes] yes zone 5: matched 13596 out of 15234 faces. zone 7: matched 13596 out of 15234 faces. Error: Failed to make zones periodic. Error Object: #f Can someone help me ?? |
September 26, 2005, 14:13 |
Re: periodic boundaries
can u specify the details of the geometry, then we can discuss about the problem - thanks!
February 25, 2012, 07:18 |
Re
mohamed khedr emam
Rep Power: 15 |
I'm now face the same problem
could any one pls, tell me how to fix this problem |
March 16, 2012, 13:29 |
Dan Barnett
Has anyone determined a solution to this problem in Fluent? I also am working on simulations that require rotational periodicy. Occasionally I am able to create the periodic zones, but sometimes I receive the errors: "Error: Failed to make zones periodic. Error Object: #f"
I believe that I am not doing anything different when I create the periodic zone successfully. I am always ensuring that the rotational axis is aligned with the z-axis of the geometry and I am using match control in meshing for the two faces of the periodic zone. Any ideas of what may casue this? |
March 16, 2012, 22:20 |
#5 | |
mohamed khedr emam
Rep Power: 15 |
Type in Fluent command Window >Mesh >mp if doesn't work try to type the following and change number >Mesh >Mz >Mt "change value (limit is 0.5)" |
March 17, 2012, 22:39 |
Snail
Rep Power: 14 |
i faced the same problem. maybe u shoud make periodic in your meshing software ,then export the grid,at last import into FLUENT、、、、、、、which meshing software you are useing??ICEM CFD can do it.
December 14, 2012, 04:46 |
Kyle Morse
Rep Power: 15 |
*I know I am late but, you must have the axis of rotation in the global z-direction for rotational periodicity. It may also be true that translational periodicity must be orthogonal across z as well.
Use /mesh/rotate in the interpreter and set your point of origin and axis of mesh rotation so that the global z-axis is parallel with the axis of periodicity use /mesh/mz/make-periodic in the interpreter and move on as usual. You can also invoke periodicity in your meshing software (* Z-axis and axis of periodicity must be parallel) and Fluent should take care of it from there. If there is a way to make the stored axis something other than (0 0 1) or any other vector, none of the above would matter. |
May 12, 2013, 09:16 |
#8 | |
ALj89
Rep Power: 13 |
The default tolerance can be problematic in small meshes just use the text command grid/modify-zone/mt and specify smaller tol's untill all nodes are matched up and then you're good to go I had to reduce from 0.1 to 1e-6 |
October 23, 2013, 03:52 |
#9 |
Rep Power: 15 |
I was facing the same problem and I solved it by changing the rotation axis on the "cell zone condition" tab. My geometry was rotationally periodic along x axis but standard fluent settings use the z axis as the rotation axis.
I hope this helps! Cheers, Rob |
October 23, 2013, 06:58 |
#10 |
vidyanand
Rep Power: 18 |
This is problem of mesh, if you not mesh same cell size and division on periodic boundaries, Fluent through this error, If you want to avoid
1.Remesh,with match control. 2.If it irregular geometry then use periodic interface in fluent ( interface option defining boundaries as interface ) |
January 9, 2014, 23:09 |
wdxgd
#11 |
It is useful,thanks
April 9, 2016, 21:01 |
#12 |
Suyash Sharma
Rep Power: 10 |
I faced the same problem and just swapped the shadow region with periodic region and the periodic zone was successfully created.
March 6, 2017, 11:52 |
#13 |
luiscssz
Rep Power: 13 |
Hi everyone,
in my case I have resolved the problem making higher the tolerance (from 0.05 to 0.1). I think the problem comes from the CAD geometry. If the periodic domains from the CAD software are not clean (that means, there are overlapping between the periodic elements), fluents doesn´t like it and appears the error. If you increase the tolerance value (grid/modify-zone/mt), fluent doesn´t take into account this ovelapping. Bye luiscssz |
March 25, 2017, 11:58 |
#14 | |
Have a nice time!
Rep Power: 11 |
warnning : your interfaces may adversely affected by the periodic creation.. what should I do? Thanks |
March 25, 2017, 12:08 |
#15 |
Have a nice time!
Rep Power: 11 |
This is my impeller and I want to make periodicity in fluent..Thanks
September 17, 2018, 07:40 |
#16 |
Kunal
How to do that in ICEM CFD?
September 19, 2018, 14:19 |
#17 |
Have a nice time!
Rep Power: 11 |
February 17, 2019, 13:56 |
#18 | |
Mehmet
Rep Power: 7 |
thanks in advance |
February 18, 2019, 05:43 |
#19 |
Rep Power: 10 |
Is your flow direction axis defined correctly in your "Cell Zone Conditions". If your direction axis is wrong, fluent wont be able to create a periodic boundary condition.
Hint: If your mesh is periodic, fluent should detect it on it's own. |
February 19, 2019, 04:13 |
#20 |
Lukas Fischer
Rep Power: 8 |
In ANSYS R 18.2 for translational cyclic boundary condition I used
the command line of Fluent to create it, following the description of https://www.researchgate.net/post/Ho...actually_means /mesh/modify-zones> make-periodic Periodic zone [()] 25 Shadow zone [()] 26 Rotational periodic? (if no, translational) [yes] no Create periodic zones? [yes] yes Auto detect translation vector? [yes] no x-direction (m) [0] 0 y-direction (m) [0] -0.0273 z-direction (m) [0] 0 translation deltas: 0.000000 -0.027300 0.000000 zone 26 deleted created periodic zones. Hint: Fluent tried to compute the delta in y-direction itself but calculated a value of -0.02731. The creation of the periodic zones failed during auto detect. Hence, I just entered the correct offset myself (Auto detect translation vector? [yes] no) and it worked. |
[ICEM] Periodic boundaries in two directions | jphastings | ANSYS | 3 | January 14, 2022 07:06 |
CGNS import in fluent - periodic boundaries. | Bjarne Børresen | FLUENT | 2 | April 25, 2013 12:12 |
Why can't I make the boundaries periodic? | Alina | FLUENT | 5 | April 12, 2012 15:06 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 12:58 |
Periodic Boundaries in GAMBIT!! | swetha | FLUENT | 1 | November 26, 2006 23:02 |
