problem with continuity residual
Old   September 16, 2005, 02:24
Default problem with continuity residual
suti
Dear All,
The scenario is a simple fire in an atrium with rectangular section. this section increases as the height increases. the fire is located in the centre of the bottom floor surrounded by 'pressure outlet' faces and there is exhaust vent (modelled as mass flow inlet)at the top floor. I use unstructured tetrahedral cells. the maximum skewness of the cell is 0.8 and there is only one cell. most of cells is in the range of 0.5. all scaled residuals are converging fine (decreasing from 1 the order of 10e-4) except continutiy scaled residual which stays between 1 and 10e-1 and it doesn't diverge.
could anyone please advice on how to improve on the continuity residual?
thank you
Old   October 3, 2005, 22:28
Default Re: problem with continuity residual *NM*
Fluentgrl
Darcy-Forchheimer law for specifying Porous Zones Ger_US OpenFOAM Running, Solving & CFD 37 April 10, 2022 04:38
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
