How to Print Forces
Old   September 9, 2005, 05:05
Default How to Print Forces
Akin
How can I print forces from external flow like, pressure forces, viscous forces etc, thanks
Old   September 9, 2005, 13:26
Default Re: How to Print Forces
Jason
From a converged solution you can print pressure forces and viscous forces (as well as total force and the same three in coefficient form) by going to Report->Forces.
While the solution is iterating you have the option built into fluent to print the total force coefficient (Viscous + Pressure force) in two directions as well as a single moment about one of the primary axis (x, y, or z). You can turn this on by going to Solve->Monitors->Forces. This is good for monitoring your model convergence, and I highly recommend doing it if you aren't already. It's not as detailed as going to Report->Forces, but it's still very useful. If you want more than that though you'll have to use a UDF, but I'm unfamiliar with how to actually go about doing this. I've personally contacted Fluent about increasing the options for force monitoring, but they just shrug it off and tell me to write a UDF.
Also, make sure your reference values are set up properly (Report->Reference Values).
Hope this helps, and good luck, Jason
Reading forces from previous time step within solver SD@TUB OpenFOAM Programming & Development 5 April 24, 2023 12:51
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat CFD XUE FLUENT 3 March 18, 2015 04:28
FORCES don't run! C12Carbon OpenFOAM 0 September 10, 2011 08:34
Calculate forces without hydrostatic pressure geir_oye FLUENT 4 November 12, 2009 10:12
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 15:09
