Modelling an aircraft intake duct
Old   September 9, 2005, 01:33
Default Modelling an aircraft intake duct
Riaan
Hi guys,
I need some help with modelling an aircraft intake duct. It is pretty much a straight pipe - but I am having problems with the Boundary conditions.
I know the following: 1) Aircraft Speed (M=0.5-0.6) and Altitude - hence, we have Static Pressure and Total Pressure 2) Mass-flow the turbine requires.
The duct starts at the inlet lip and stops just upstream of the turbine.
What B.C. should I use?
Old   September 9, 2005, 04:22
Default Re: Modelling an aircraft intake duct
Ahmed
You have extended the mesh,Right, so the inlet is far field BC
Old   September 9, 2005, 09:08
Riaan
Well, I have extended the flow-field upstream of the lip, but I cannot use Pressure Far Field, since the PFF boundaries touch the walls of the duct
Old   September 10, 2005, 09:00
Ahmed
1- As far as I understand the geometry, You seem to be interested in the internal flow, but how about the intake geometry shape itself and its effects on the flow field (Intake Aerodynamics by J. Seddon and E.L. Goldsmith or Inlets for Supersonic Missiles by John J. Mahoney for more details). Why are you surprised by extending the mesh? is that a professional job or home work for your CFD class? 2- Could you please send an iges file of your geometry (or an image file) 3- You could read the tutorial on the flow around a wing section (your domain is just two of them) Hope that will help, good luck.
Old   September 13, 2005, 11:23
Riaan
Hi Ahmed,
This was a first test case, and currently I have the duct imbedded into the fuselage to model it inlet lip and fuselage effects.
- The "duct inlet" condition will be determined by the external aero, and the outlet will be Pressure Outlet with Target mass-flow specified.
- This is for work, so I am not allowed to release any drawings...sorry...
Regards Riaan
Modelling free falling water into a air filled duct? sandmike_83 CFX 4 August 24, 2010 04:27
Modelling an intake system hvem10 FLUENT 3 November 5, 2009 07:26
Inlet shapes for modelling a fan in an inlet duct buzzybee CFX 10 June 11, 2009 21:15
modelling fuel cell duct in fluent rajesh kumar tippabhotla FLUENT 2 October 7, 2004 13:04
Stokes number for intake duct bend Friederike FLUENT 0 July 30, 2004 05:12
