Bubble Column Modelling
Like Tree1Likes
Old   January 27, 2015, 00:08
Thành
thanhvn is on a distinguished road
Originally Posted by azna View Post
Hi ,
I need to simulate a bubble column with Eulerian model in Fluent, However I don't know how can I define bubble sizes between 3 to 4 mm instead of a constant bubble size ? in the phases there is a option to define bubble diameter but it's only for constant value .
Thanks
Hi Azna
U could define bubble diameter in path min/max diameter at the end secondary phase panel.
Enjoy.
thanhvn is offline   Reply With Quote
Old   September 29, 2015, 02:55
Default 2d bubble column
  #22
surya
surya.tdr is on a distinguished road
The reactor i need to simulate is a bubble column (2d). To create bubbles i made the gas inlet pipe with perforations and used euler-euler model for setup. I need to get a continuous flow of bubbles but when i animate and see the air flow is not uniform and air is not coming through all perforations. I doubt whether the geometry is creating any problem. Kindly help me and if my problem is not yet clear i can explain more.
surya.tdr is offline   Reply With Quote
Old   August 29, 2017, 06:11
Default Tutorial for bubble column
  #23
Ritesh
ritesh.prakash is on a distinguished road
Can anyone send the link for the tutorial for bubble column...
ritesh.prakash is offline   Reply With Quote
Old   September 10, 2017, 05:17
Default Random parse error FLUENT 18.0
  #24
Cees Haringa
CeesH is on a distinguished road
What's the timestep size you are using. 2 phase modeling is quite sensitive to it.
CeesH is offline   Reply With Quote
Old   October 31, 2017, 07:01
Default average volume fraction
  #25
Ritesh
How to get the average volume fraction of air in the two-phase system?
two phase modelling in bubble column srikkanth FLUENT 1 March 27, 2017 10:21
bubble column ken FLUENT 1 June 30, 2013 02:18
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 09:59
Help required for CFD simulation of Trayed Bubble Column using Fluent art705 Main CFD Forum 0 July 15, 2009 05:04
INLET BOUNDARY FOR BUBBLE COLUMN Swarnendu CFX 1 July 5, 2004 03:16
