September 7, 2005, 12:59 |
Fluent -> ParaView
Anyone know if Fluent data can be read by the post processor 'ParaView'.
Had a bit of an explore and it don't seem to want to work. Any experience out there? |
September 8, 2005, 04:12 |
Re: Fluent -> ParaView
Yes, it can be done. Export to Ensight binary format, read the resulting *.encas file into Paraview with the "Little-endian" option.
September 8, 2005, 13:39 |
Thanks - will try.
September 8, 2005, 15:45 |
One thing I did have to do in case others are reading.
Rename the *.encas file to *.case. Anyway this worked for me! |
September 8, 2005, 16:30 |
The .encas --> .cas rename is not strictly necessary. You can force Paraview to list all the files in the directory (otherwise it only lists the files with extensions familiar to it) and then select the Ensight files reader when it asks which reader to use. You can also use the ASCII format Ensight files, but you need to strip the leading spaces from all lines containing character strings.
September 9, 2010, 04:13 |
Claudio C.
Rep Power: 16 |
I tried to open .cas and .dat file from Fluent in Paraview, but I'm not able to see the results in the right way. The 3D model is opened and I can see velocities, for example. But I can't see the right countour velocity map.
So I tried to export datas from Fluent in EnSight format. But Paraview gives this error: ERROR: In ..\..\..\src\Servers\Filters\vtkEnSightGoldBinaryR eader2.cxx, line 94 vtkEnSightGoldBinaryReader2 (046867F0): stat failed. ERROR: In ..\..\..\src\Servers\Filters\vtkEnSightGoldBinaryR eader2.cxx, line 136 vtkEnSightGoldBinaryReader2 (046867F0): Unable to open file: C:\Users\Utente\Desktop\How to use Paraview\Hybrid 020 010 005\/hybrid ERROR: In ..\..\..\src\Servers\Filters\vtkEnSightReader2.cxx , line 307 vtkEnSightGoldBinaryReader2 (046867F0): error reading geometry file ERROR: In ..\..\..\src\VTK\Filtering\vtkExecutive.cxx, line 756 vtkCompositeDataPipeline (047AAA60): Algorithm vtkEnSightGoldBinaryReader2(046867F0) returned failure for request: vtkInformation (04823518) Debug: Off Modified Time: 98830 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FROM_OUTPUT_PORT: 0 FORWARD_DIRECTION: 0 ALGORITHM_AFTER_FORWARD: 1 ERROR: In ..\..\..\src\Servers\Filters\vtkGenericEnSightRead er2.cxx, line 465 vtkGenericEnSightReader2 (047AC148): Unable to open file: C:\Users\Utente\Desktop\How to use Paraview\Hybrid 020 010 005\/hybrid Warning: In ..\..\..\src\Servers\Filters\vtkGenericEnSightRead er2.cxx, line 466 vtkGenericEnSightReader2 (047AC148): Assuming binary file. What can I do? |
July 28, 2015, 10:08 |
thomas
Rep Power: 12 |
Hi Claudio,
any luck with your problem (I know you posted it about 5 years ago!)? I am having a similar one. Thanks in advance! |
August 21, 2015, 11:23 |
Claudio C.
Rep Power: 16 |
Hello Thomas,
Did you try to convert Fluent .cas and .dat files into Ensight gold format before opening them in Paraview? Try also to change the extension .encase to .case manually. |
August 22, 2015, 04:40 |
#9 |
thomas
Rep Power: 12 |
I tried that and it worked! Thanks.
August 19, 2019, 05:11 |
#10 | |
Vignesh Lakshmanan
Rep Power: 10 |
Sorry for restarting the thread again. I just wanted to know if there is any difference between .encas and .case files? For an application, I need airflow data from Fluent in ensight case gold (.case ) format. But, I am able to export only .encas format from Fluent and the intended application is not able to read this format!!! Can I export .case format form Fluent? Or your suggestion to just rename the file would suffice? Thanks and Regards Vignesh |
August 21, 2019, 05:14 |
#11 |
Rep Power: 10 |
You can export your Fluent data as a Tecplot file which works with paraview
September 7, 2020, 08:47 |
#12 |
Tobias Holzmann
Rep Power: 52 |
Hi all,
I am trying to convert Fluent data for ParaView too. However, I am unable to get it work.
Any idea?
Keep foaming, Tobias Holzmann |
September 7, 2020, 10:46 |
#13 | |
Saikumar Reddy Y
Rep Power: 6 |
1. Copy all your fluent results files to any of your tutorial cases in your run directory. 2. Change your startTime to latestTime in system/controlDict 3. You can delete the contents of 0 time folder which will be later created with data from fluent t=0 time file. 4. Write a shell script (if you have multiple files) The algorithm looks as follows, a. Read the .cas file using ' fluentMestToFoam meshfile.cas' b. Iterate over the number of .dat files in the folder, c. Use a for loop to iterate - read the dat file 'fluentDataToFoam result_t_*.dat' - make a new directory with mkdir command for the next time step (Ex: mkdir 't+dt') end So the theme of the shell script is to create a time file by converting each of the fluent .dat file to OpenFOAM format. 4. Now use the simple paraFoam command to read your data. This procedure can be further used to simulate the flow in OpenFOAM and validate your results. I use Fluent for steady state simulation for the lack of steady density based solver in OF, however I continue the transient simulation in OpenFOAM using the above procedure. In my case, although I only have one .cas and one .dat file. |
September 7, 2020, 14:05 |
#14 |
Tobias Holzmann
Rep Power: 52 |
Interesting point. Never thought about going the way via OpenFOAM format. I found the error. It is related to the latest Fluent release 20 R2 --> I had to load the data using 20 R1 and then it worked.
Nevertheless, I keep your idea in my mind but I don't have FOAM on the machines on the working stations at my company.
October 1, 2020, 06:35 |
Solution to the Fluent 2020 R2 -> Ensight Gold Data -> Paraview Problem
#15 |
Hey together,
by starting my masters thesis in the last few weeks I ran into the same Problems between Fluent and Paraview, utilizing the EnSight data format, that you guy's mentioned previously. Long story short, I came up with a sulution. At least for anyone that uses the Fluent 2020 R2 release: Your Ensight .encas-file looks after the export somewhat like the example beneath. Paraview seems to have Problems with the ""-marks, which hold certain filenames, and doesn't support the whole SCRIPTS-section of the file. If you remove the problematic bits of the file (marked in red) and save it as .case-file, you should be good to go importing your solution data in Paraview. However, be careful to no leave a blank line at the end of the textfile. This, for some reason, sends Paraview in a inf-loop while reading the data. Code:
FORMAT type: ensight gold GEOMETRY model: 2 2 "generic_meshfile.geo" VARIABLE scalar per element: 1 1 total_pressure "generic_solution_variable.scl1" vector per element: 1 1 velocity "velocity_solution.vel" TIME time set: 1 Model number of steps: 2 time values: 2.59587e-09 1.86688e-08 time set: 2 Model number of steps: 1 time values: 2.59587e-09 FILE file set: 1 number of steps:2 file set: 2 number of steps: 1 SCRIPTS metadata: "generic_metadata.xml" Moerten |
November 10, 2020, 09:46 |
#17 | |
SF
If you want to export a non Dynamic Mesh, cgns format works fine on the latest ParaView version |
January 28, 2021, 08:33 |
How to import Fluent .cas.h5 to ParaView?
#18 |
Lukas Fischer
Rep Power: 8 |
so far I was able to import .cas and .dat binary files with ParaView 5.0.1. The latest ANSYS release like 2020 R1 saves the .cas.h5 and .dat.h5 files. Hence, I downloaded tested the latestet ParaView versions (5.9.0 and 5.8.0). I get the following error, when trying to import the .cas.h5 file with the "fluent case reader": vtkFLUENTReader (0xa6e1d080): Could not open data file my_path_to/fluent.casdatassociated with cas file my_path_to/fluent.cas.h5. Please verify the cas and dat files have the same base name. Both files have the same name: fluent.cas.h5 fluent.dat.h5 so I do know what ParaView wants. When I export the fluent data to ensight I end up with a .cas and .cdat file. The .cas can be read and I see the mesh but not the data. Converting Fluent data to Foam was always messy for me, too and I do not want to go that way either. I would like to save time just use the .cas.h5 and .dat.h5 files. This way I do not have to open fluent and change the format for ParaView. How to import Fluent .cas.h5 files to ParaView? |
January 28, 2021, 09:11 |
#19 |
Hi Lukas,
are you sure you used Ensight-gold? Iam not aware of any possibility to read .cas.h5/.dat.h5 files with Paraview. But, if you have been able to read .cas/.dat-files with a previous version of Paraview, there is a default I/O option in the preferences of Fluent 2020R*. Set this option to "Legacy". This might help in your case. Nevertheless, i am pretty sure this won't work for more complex situations eg. dynamic meshes, because fluent denies to write the dynamic-mesh info into legacy files. Good luck |
January 28, 2021, 09:55 |
#20 |
Lukas Fischer
Rep Power: 8 |
this was helpful, since I cannot reach the ANSYS Support (I guess their support website is down). It works this way (using ParaView 5.0.1 so I guess the newer ones will work, too). I opened the .cas.h5 files with Fluent and was able to save them to .cas files. You have change I/O to legacy as you mentioned. Otherwise Fluent ignores your command to save it to .cas and saves it as .cas.h5 again . File/Preferences/Default Format for I/O => Legacy If I will encounter problems with the dynamic mesh adaption I will try to find a solution. To get the Ensight format I talked about I did this in Fluent R2020 R2: File/Export to CFD-Post The file type is called: CDAT for CFD-Post and EnSight. I have not used Ensight Gold yet. Lukas |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
Fluent to Paraview | Lilly | FLUENT | 2 | September 19, 2012 13:40 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 03:44 |
From FLUENT data to Paraview | bart weisser | FLUENT | 1 | July 16, 2010 05:41 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 17:41 |
