need some suggestion
Old   September 7, 2005, 03:50
Default need some suggestion
nabeel
hi i am finding heat transfer coffecient for coolant in channels of combustion chamber .the goal of my simulation is to calculate heat transfer coeffecient through species transport.i am using segregated solver and no diffusion b/c of species transport through convection. i am using mass flow inlet and pressure outlet and wall BC.
my fluid is only liquid how i off mixture template. second my solution is not converging what should i do.i tried after reducing relaxation factor . my residuals have oscillation pattern after 200 iteration. nabeel
suggestion for thermophysicalproperties for high temperature buoyant flow braennstroem OpenFOAM Running, Solving & CFD 0 March 21, 2011 15:06
any suggestion about method to use? cnmm Main CFD Forum 0 May 29, 2009 00:13
Suggestion to make spray simulations more stable fabianpk OpenFOAM 4 October 16, 2007 07:53
To webmaster or forum modulator: a suggestion ma Main CFD Forum 16 December 11, 2004 11:56
can you give me some suggestion? reck Main CFD Forum 0 November 25, 2001 01:40
