Reading distributions along the edge of a circle
Old   September 6, 2005, 19:05
Default Reading distributions along the edge of a circle
Satish Perivilli
Hi
I wanted to know if there is a way in which I could read off/export a variable distribution along a circle ( only along its edge, not the whole plane). I have a 3D geometry which looks like a brick, and I am trying to read off temperature distribution along the edge of a circle with any given radius, within the geometry.
Any help would be appreciated, thanks
Satish
Old   September 6, 2005, 21:58
Default Re: Reading distributions along the edge of a circ
Sham
hi,
I am not sure if this will help or not. In the Plot xy window, select curve length instead of direction vector.
Sham.
Old   September 7, 2005, 19:00
Satish Perivilli
Hi Sham
thnx for the response. I tried doing something with that, but couldnt actually figure out how to use it I guess. For example, if I were to read the temperature distribution along a circle of radius = R, then how would I do that?? Can you please eloberate??
Thank you
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 07:37
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 07:28
