UDF problems
Old   September 6, 2005, 13:44
Default UDF problems
Paolo Lampitella
Hi to everyone (sorry for my english) I'm having some problems with UDFs. The first is: what is a "parse error"? I already had this error for having too much variable declaration in the same row but now Fluent gives me the error for the line:
"c=a+b;" obviously i declared all the variables and defined the values for "a" and "b" so...i don't know how to proceed. The second one is about the threads: can i define, via UDF, a new cell thread specifing what are the cells that i want to put in it?
Thanks
Old   September 6, 2005, 14:09
Default Street Canyon msh file??
Aykut
Hi everybody;
I am a master degree student and I have a thesis topic of "Simulation of a flow in a Street Canyon". So I am a new user of both Gambit and Fluent Softwares. My first aim is to create a 2D and then a 3D Street Canyon Geometry and to mesh it.2D seems easy but with 3D i have no clue. Soooo if any of you have a basic simple 3D street canyon model and share it with me I will be sooooo satisfied. Thanxx for your cooperation. Bye
Old   September 6, 2005, 19:07
Default Re: UDF problems
Amir
it would helpful if you post your UDF here to have a look
Old   September 6, 2005, 21:38
Ahmed
the parser reads your c statements and converts them to the equivalent in machine language, if it is not a problem for you go again through the spelling especially the lines before this statment or if you have a C++ compiler (if you are using a UNIX or LINUX machine then it is the cc command, check your man command for details) then transfer the code and recompile it again, if there is a spelling error it will give you better error message and even the line number
Old   September 7, 2005, 11:23
Default UDF problems 2
Paolo Lampitella
Thank you Amir and Ahmed for your help; i solved the problem but now i'm experiencing some other problems, take a look, please:
thread_loop_c(t,domain)
begin_c_loop(c,t)
C_CENTROID(xc,c,t);
dist=sqrt(pow((xc[0]-bar[0]),2)+pow((xc[1]-bar[1]),2)+pow((xc[2]-bar[2]),2));
if ( dist < d )
d=dist;
C_CENTROID(xc1,c,t);
cid=c;
end_c_loop(c,t)
printf("cid = %d\n", cid);
c_node_loop(cid,t,n) /*line 182*/
ny=NODE_Y(n);
d2=fabs(ny-bar[1]);
if (d2>d1)
d1=d2;
This is only the final part of my udf (too much big to post it all) but is where i have the error:
"C:\Fluent.Inc tbin tx86\cpp.exe -IC:\Fluent.Inc\fluent6.2.16/src -IC:\Fluent.Inc\fluent6.2.16/cortex/src -IC:\Fluent.Inc\fluent6.2.16/client/src -IC:\Fluent.Inc\fluent6.2.16/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" C:\Fluent.Inc tbin tx86\profili_source.c Error: C:\Fluent.Inc\ntbin\ntx86\profili_source.c: line 182: non-integer subscript expression: unsigned char."
But if i cut the c_node_loop he recognize the value for cid and the UDF works correctly writing it on the screen... oops, i forgot to say that it is a "DEFINE_ON_DEMAND" macro (i don't know if it is important).
Thank you
Old   September 8, 2005, 21:43
Default Re: UDF problems 2
Ahmed
Check the number of the closing braces "}". As I said in a previous posting, use any available C compiler to check your code, most books about the C language that I know about come with MS VC. The C language is one of the most powerful programming tools today, but you have to strictly follow its syntax. Good Luck
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 07:43
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
problems with UDF to set contact angle poiuy219 Main CFD Forum 0 April 30, 2009 11:43
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
