August 31, 2005, 03:12 |
Urgent help about mixture model
In my project, I have to use the mixture model in Fluent to simulate tha gas-solid flow field in a cyclone. In my cyclone inlet, the solid particle have a wide size distribution, so I have to treat different size particle as different phase. In my work, I have to calculate the grade efficiency, so I should add five phases at least. I deselect the volume fraction and slip velocity at first, and when the residuals are flat, I select these two terms. However, when I calculated it again, the following errr is listing: Error: Floating point error: invalid number
Error Object: () At the same time, the residuals jump to a high value (for example,10e4). I don't know what leads to this. Hope someone can help me. Thanks in advance. |
Mixture model and kinetic theory | Fuping Qian | FLUENT | 3 | January 24, 2011 07:58 |
species transport model or mixture model? | achaokaoyan | Main CFD Forum | 0 | July 10, 2010 11:52 |
Mixture model for air-water | Babak | FLUENT | 0 | June 21, 2010 17:58 |
plz rply urgent regrding vof model for my system | garima chaudhary | FLUENT | 1 | July 20, 2007 09:37 |
Converge problem of Mixture Model | Jen | FLUENT | 8 | August 17, 2005 19:23 |
