Setting pressure value for specific cells, UDF
Old   August 29, 2005, 15:37
Default Setting pressure value for specific cells, UDF
Amir
Hello, I am trying to control the pressure for few specific cells in the domain by a UDF but haven't been successful yet.
as I read in the UDF manual I have to use DEFINE_ADJUST for that. now the question is how I should assign a specific value for those cells.
Here's the code I wrote but doesn't work yet. The code wants to assign the pressure value of 500 for a band of cells within the +- delta width in y direction and between x1 and x2 in x direction.
Any hint is appreciated
/ UDF for satisfying the specific boundary conditions at
/ the interface
#include "udf.h"
#define delta 0.0003
#define x1 0.0532
#define x2 0.4092
#define y1 0.00635
#define y2 0.121
DEFINE_ADJUST(interface_adjust,d)
Thread *t;
real x[ND_ND];
cell_t c;
C_CENTROID(x, c, t);
if (x[0] <= x2 & x[0] >= x1)
C_P(c,t) = 100;
if (x[1] > y1 - delta & x[1] < y1) C_P(c,t) = 500;
if (x[1] < y1 + delta & x[1] > y1) C_P(c,t) = 500;
if (x[1] > y2 - delta & x[1] < y2) C_P(c,t) = 500;
if (x[1] < y2 + delta & x[1] > y2) C_P(c,t) = 500;
Old   August 30, 2005, 17:41
Default Re: Setting pressure value for specific cells, UDF
Alec Eiffel
i think you need to put a cell loop to change the values in the cells.
something like
thread_loop_c(t,d)
begin_c_loop(c,t)
your_code_here
end_c_loop(c,t)
Old   September 1, 2005, 19:59
Amir
Thanks Alec, It was certainly useful
correct UDF code for unsteady pressure boundary James W FLUENT 0 November 2, 2005 12:38
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
Warning 097- AB Siemens 6 November 15, 2004 05:41
UDF: neighbour cells, upwind cells Dmitriy Makarov FLUENT 0 February 18, 2001 14:53
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
