Memory size on disk, help!
Old   August 27, 2005, 23:48
Default Memory size on disk, help!
Pah
Hi Everybody!
I have a question about Memory on disk in solving Fluent. I use around 1.3 million nodes, but the memory is near 1.4 GB on RAM.
Could anybody show to me how to reduce memory size , and increase solving Speed in FLuent?
Manythanks, have a nice weekend to all friends!
pah
Old   August 30, 2005, 06:42
Default Re: Memory size on disk, help!
Christopher Rand
With a model this large I presume you are parallel processing (dual processor workstation or network). I use a dual processor machine and I recently discoved the benefits of reordering the grid domain (Grid/Reorder/Domain). Reordering your grid domain will probably reduce your model bandwidth considerably, speeding up the solution time. If you reorder a couple of times the reported reduction ratio will approach 1 which is the optimum condition.
As far as memory goes the best approach is to make sure that you need all these nodes. Is the grid density too dense in areas where it doesn't need to be. It is usually better to start with a courser grid and to use grid adaption to focus on the important flow conditions.
Hope this helps,
Chris
Old   August 30, 2005, 23:30
Pah
Hi Chris!
Thank you for your detailed recomendation. The reodering command for Grid will speed up the solution, and we do not have any other options to increase it.
Thanks once more!
pah
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
