Grid Check Error
Old   August 25, 2005, 18:26
Default Grid Check Error
sak
Hi all, iam getting a warning sign saying the Grid Check failed, can anybody tell what the reason is. thnx in advanced.
Old   August 25, 2005, 18:39
Default Re: Grid Check Error
seabstian
Check your blocks for orientation. There might be a block that has negetive volume cells in it.
Old   August 25, 2005, 21:05
sak
thnx for the response but can you tell me how to check the blocks for orientation. thnx in advance.
Old   August 26, 2005, 03:27
Pah
Hi
Fluent warns you about the "Grid Check Failed" I think the problem is negative volume in your Calculational domain. It will appear the value of negative volume in Fluent. You can see it. In my experience, you should not solve Domain so much!
hope this help!
pah
Old   August 26, 2005, 05:10
Mario
You can already check for negative volumes in gambit. Use the option examing mesh with volume as quality kriterion and a range from -1 to 0. You maybe avoid having to export the mesh again.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
