Help:What's wrong with my porous zones setting!!?
Old   August 25, 2005, 05:31
Default Help:What's wrong with my porous zones setting!!?
jjw
Hello,I study in fluent recently ,not konw well in this programe!help me ,please !it's about my paper!^_^ My purpose is let air through a porous zones to reach another side ;but i find the air cannot through the porous zones(in gambit I setting porous zones in "zones-specify continuum "type as fluid is that all right??) then,i check the gird in fluent 6.1,and i find at the boundary of fluid face and porous zones faces they are not interior but wall,is that the main problem, and how to solve it! what's more,this is only my first time to touch fluent 6.1 and this i wanna solve single-phase first,if everthing run well i need solve mutiphases quessions!
Old   August 25, 2005, 06:43
Default Re: Help:What's wrong with my porous zones setting
Ralf Schmidt
Hi
Your problem ist the difinition of the volumes in Gambit. The two volumes (one fluid, one porous zone) have to be seperatet by the SAME face!
So check your volumes in Gambit and make sure, that both are using the same face. If there is any face, that is not used by a volume, fluent will transform it into a wall.
Refere also to
http://www.cfd-online.com/Forum/fluent.cgi?read=30516
Old   August 26, 2005, 06:16
jjw
to Ralf Schmidt :
thank you !you are right ,i check it in Gambit and find the two faces not use the same edge,and i konw it must use "split" to split face to faces!
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
udf error srihari FLUENT 1 October 31, 2016 15:18
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
