UDF and AMG solver crash
Old   August 23, 2005, 19:07
Default UDF and AMG solver crash
Josef
Please, could you help me with a boring problem. I'm using UDF for modeling chemical reaction in porous media. It's a tube reactor with catalytic layer where the reaction occurs. I have to use UDF, becasue there is no way how to do that directly in Fluent, or is there? And when I use my UDF (source terms) it always stops with this message: Error: divergence detected in AMG solver: species-1 Error Object: ()
Does anybody know what is it? Or what can cause this problem? Thank you very much, I cannot overcome this problem. Or if you have better solution how to solve this system I will appreciate your help.
Josef
Old   August 25, 2005, 08:19
Default Re: UDF and AMG solver crash
Luc
I have the same problem for a similar process. "Error: divergence detected in AMG solver: species-1" might mean that your source term is too high and that provokes thus unrealistic species mass fraction. As a result the case can not converged. There are two ways to overcome this. First decrease the under relaxation factor of the reacting species. If not sufficient, you can perform some test to identify the part of your udf which causes problem. Set the source term to a constant value then to the correct/10000 to see if the divergence comes really from a too high source term.
Luc
Old   August 25, 2005, 09:07
Josef
Luc, thank you I will try it.
Divergence detected in AMG solver: pressure correction emlejeen FLUENT 5 December 15, 2016 00:47
divergence detected in AMG solver selvaganesh FLUENT 5 February 5, 2014 04:55
divergence in AMG solver Merinadica FLUENT 0 December 5, 2006 09:17
Divergence in AMG solver: species-4 BillChen FLUENT 1 July 15, 2006 02:14
AMG solver error Matthew Brannock FLUENT 1 July 13, 2001 19:32
