Can Fluent be used to simulate IC engine flows?
Old   August 23, 2005, 09:25
Default Can Fluent be used to simulate IC engine flows?
Jimmy Fox
Hi there:
I am thinking to use Fluent to simulate IC engine combusiton flows. It seems most people use Star-CD, KIVA, etc for this purpose. Who can tell me if there is any problems with Fluent? Thanks a lot.
Jimmy
Old   September 7, 2005, 11:35
Default Re: Can Fluent be used to simulate IC engine flows
Vinod Dhiman
Hi
There is no problem with Fluent if you use it for IC Engine flow simulation. It is done here in our lab. However, if you are simulating the flow using combustion then its better to use CFX or Star-CD, and if you want to track the flame then KIVA is better. But if you want to simulate flow without combustion, which is not handled as better by Fluent, then its good enough.
Vinod Dhiman
IC engine simulation tutorial by FLUENT yash Main CFD Forum 1 April 21, 2009 06:05
Can I simulate crystal using FLUENT windman FLUENT 1 January 18, 2006 07:34
Can I Simulate PLASMA with Fluent Patel Amit FLUENT 5 December 30, 2005 05:07
May fluent can simulate heat and mass transfer? yueroo FLUENT 3 April 24, 2001 12:19
ability of fluent to predict scalar fields in reacting flows ? Mounir Main CFD Forum 1 January 21, 1999 11:08
