August 22, 2005, 17:55 |
How to obtain forces
I am interested in obtaining the forces Fl,Fd,Fmy where Fl=lift force Fd=Drag force and Fmy=Moment about y-axis I know that fluent gives the Cd,Cm and Cl, but I will like if anyone knows how to obtain the forces. Thanks to all
August 22, 2005, 18:25 |
Re: How to obtain forces
I'm assuming you're talking about when you monitor forces (when you Report->Forces it lists the force and the coefficient).
If you set RHOref=2, Vref=1, Aref=1 and Lref=1 in the reference values window then you'll get forces (check your units though!) Remember: F=(1/2)*RHOref*Vref^2*Aref*Coef and M=(1/2)*RHOref*Vref^2*Aref*Lref*Coef So by setting the values I gave earlier, you've simplified the formulas to: F=Coef and M=Coef But like I said, double check your units. Hope this helps, and good luck, Jason |
August 22, 2005, 18:26 |
Thanks Jason
Reading forces from previous time step within solver | SD@TUB | OpenFOAM Programming & Development | 5 | April 24, 2023 12:51 |
How to calculate pressure forces using custom field functions? | tsagaro | FLUENT | 7 | June 23, 2017 16:45 |
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat | CFD XUE | FLUENT | 3 | March 18, 2015 04:28 |
FORCES don't run! | C12Carbon | OpenFOAM | 0 | September 10, 2011 08:34 |
Valve Forces in CFdesign | Mike Clapp | Main CFD Forum | 3 | March 8, 2001 15:09 |
