August 22, 2005, 10:54 |
Convergence issues
Dear all:
I was trying to model a pretty huge pipe with lots of bends and all and with an inlet velocity of 27 m/s. the total span of the pipe on x dir would be around 10m and y would be around the same. i was trying to model a part of a pipe in a power plant. the problem was that i was getting divergence when i used an unsteady implicit solver..any thoughts...or is it just that the whole system is just very unstable one?? thanks in advance |
August 22, 2005, 11:44 |
Re: Convergence issues
this will need very good mesh i guess. i will say system is quite wild!
August 22, 2005, 15:08 |
hi derick i think u dont have to model the whole pipe at same time. try model a type of geometry (means pipe of certain dia with certain bend angle)one by one. and for similar type just add the losses etc.
i hope i made my point clear.(divide and rule) |
August 22, 2005, 15:57 |
Try one or all of these to see if it works - smaller time-step size, smaller under-relaxation factors (segregated solver) or CFL number (coupled solver).
August 22, 2005, 16:09 |
thanks guys for ur help..i will surely try all ur suggestions. hope they work...thanks once again guys
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
convergence issues on steady state solver | icemaniac178 | CFX | 1 | March 30, 2011 20:11 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
Grid size, convergence issues | franzdrs | Main CFD Forum | 3 | June 18, 2009 08:57 |
