HELP temp distribution on solid when dip in fluid
Old   August 22, 2005, 03:53
Default HELP temp distribution on solid when dip in fluid
MANOJ
hello i doing one problem in which a thin sheet of 5mm thick and long 1 m and width 50mm and dipping in cube of 1 m my problem is modeling in Gambit that which type of model taken means if take cube as solid and sheet as a air whose viscosity is kept high
CFB+wall BC for solid vel and gran temp Umesh FLUENT 2 September 10, 2013 18:21
conjugateHeatFoam: Should solid and fluid have the same mesh at the coupled boundary? awacs OpenFOAM Running, Solving & CFD 6 September 22, 2009 23:58
fluid or solid ??? Krish FLUENT 1 June 24, 2009 05:38
Conjugate Heat Transfer between fluid and solid Li Yang Main CFD Forum 8 March 27, 2004 12:05
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
