How to input dimensionless parameter in FLUENT |
August 21, 2005, 15:02 |
I will solve heat transfer problem. But the temperature is fictitious dimensionless. So I want to know hot to input dimensionless temperature of inlet flow. Of course, density, conductivity and specific heat are also dimensionless.
Thanks in advance. |
August 22, 2005, 15:13 |
Re: How to input dimensionless parameter in FLUENT
All you have to do is to make sure you're matching the relevant parameters such as Prandtl number and Rayleigh number, and use proper non-dimensional quantities when comparing the results with the data or correlations.
August 23, 2005, 04:25 |
Hi my friend I think it is usefull to refer to this forum: http://www.cfd-online.com/Forum/fluent.cgi?read=30267
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
TUI Mass-flow-rate input with Fluent 6.1 | Jeremy | FLUENT | 0 | December 12, 2005 15:00 |
