udf in MRF to update the rotational speed
Old   August 21, 2005, 13:50
Default udf in MRF to update the rotational speed
Jam
Hi there, I need to update rotational speed according to the moment constant I monitor from the Force monitor, while using an MRF model. I am able to do this manually but I want to make an udf that will do this job for me automatically. I figured out that I can reach the angular velocity variable by THREAD_VAR(tc).fluid.omega if I unterstood it correct. But how can I reach the moment constant which is represented as fmon/cm under the transcript file. And after completing the c file can I use interpreted? How to hook the udf for the rotational speed? Does it go automatic? If it is so what should be written in the rotational speed part? If anyone can reply any of the questions I will be so glad. Thanks indeed.
Regards,
Train Speed yeo FLUENT 5 February 14, 2012 09:38
UDF programming fullmonty FLUENT 5 June 30, 2011 03:40
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
(CFX POST) Rotational Speed ARJUN CFX 9 July 13, 2006 21:38
Rotational speed Ruben FLUENT 2 December 3, 2004 09:38
