Cell Reynolds number
Old   August 20, 2005, 05:30
Default Cell Reynolds number
cfd help
Any thoughts on why 'High Cell Reynolds Numbers' do not overlay on regions of high velocity?
I have a simple flow case, isothermal and incompressible and yet the High Cell Reynolds Numbers are on the boundaries and not overlaying the high velocity of the flow inlet.
Naturally there is shear at the boundaries, yet 'High effective visocity' is also not aligned with the high Cell Reynolds Numbers.
The mesh is uniform and cartesian.
Old   August 22, 2005, 11:50
Default Re: Cell Reynolds number
swarup
is effective viscosity low near boundaries/turbulence effect is weakened near boundaries?
Cell Reynolds Number laliong Main CFD Forum 12 September 17, 2019 04:18
Two way particle coupling in OF 2.0 and the particle reynolds number preichl OpenFOAM 7 February 9, 2012 16:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
cell number in radpro.f ? Ossi Siemens 1 April 5, 2002 08:48
