August 19, 2005, 15:51 |
fluent 6.2 and computer?
wat u ppl would suggest in terms of computer power and company for running fluent 6.2 for turbomachinery . currently i am using mixing plane and simulating more than 2 stages
August 20, 2005, 15:57 |
Re: fluent 6.2 and computer?
Here is a reference point for you:
Computer: dual Opteron 246, MB Tyan K8W, 4GB Corsair OS: Windows 2000 Professional Software: Fluent 6.2 Case: Rotor 37, 420.000 elements structured grid, 2 Metis partitions Solver: Coupled Implicit Performance: - serial 22 sec/iteration - parallel 15 sec/iteration Testing the same case with 64 bit Fluent on WhiteBox Linux 4 I get a 27% improvement for serial case. BUT! Pay attention that this is a case where data transfer between processors is pretty large compared to the size of the grid (6.7 MB/iteration, value equal to that obtained for a 2.1 milion!!! cells segregated incompressible case, for which parallel performance was 110% vs 64% for current case) and this is mainly due to the coupled solver. For a segregated solver or a coupled explicit solver things are a little brighter (these ones do not require such intense data transfer between processors). So, I'd say that for 3-4 stages coupled through mixing plane interfaces, 1.5-2 milion cells maybe, you would need a minimum of 4 processors cluster (my suggestion: AMD64 3500+, socket 939 AT LEAST, 2GB RAM/processor, GigabitEthernet connection) running 64 bit Fluent on Linux. With a good partitioning you could get less than 25 sec/iteration solving with coupled implicit. Best wishes, Razvan |
August 28, 2005, 03:58 |
thanks for ur suggetion.
sam |
Fluent 6.2 & Gambit on Windows XP x64 | AcoidanBM | FLUENT | 9 | October 30, 2011 15:08 |
Chose a new computer to run ANSYS FLUENT | josenandopr | ANSYS | 3 | December 22, 2010 11:32 |
New computer for CFD simulations using FLUENT | Malik1 | Hardware | 3 | August 11, 2010 02:44 |
Computer Requirements for Running Fluent | Chaitanya Varma | FLUENT | 1 | February 23, 2007 14:03 |
A computer to run Fluent - 64 bit? | Mike | FLUENT | 3 | September 23, 2005 11:27 |
