LES turbulence model problem-HELP
Old   August 18, 2005, 05:33
Default LES turbulence model problem-HELP
James Willie
Hi All,
I am simulating gas oil and I have a problem with the LES turbulence model. It is working alright but the peak temperature i am getting is 2000K where as for the k-e realizable turbulence model, i am getting a peak temperature of 1800K in the combustor.
Also, the flame shape has changed for the LES. The steady RANS and unsteady RANS cases have a reasonable flame shape. Any explanation for this discrepancy and suggestions of how it can be solved?
For the sub-grid model under LES, i am using Smagorinsky-Lilly.
James
Old   August 22, 2005, 16:22
Default Re: LES turbulence model problem-HELP
helper
Higher peak temperature with LES is not surprise to me, inasmuch as LES resolves finer scales of motion and temperarure field. Regarding the flame shape, chance is that instantaneous flame shape in LES has lots of wrinkles in it. You've got to compare the time-averaged flame shape with the RANS-based shape.
Old   August 23, 2005, 05:54
James Willie
Thanks for the help. Will this temperature drop with time? That is what happens after allowing for sufficiently large number of iterations?
Also, how is the time averaged flame temperature obtained? Is it obtained by switching on "Data Sampling for Time Statistics" under "Option" on in the "iterate" panel?
Regards,
James
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 21:21
LRR turbulence model gianlu OpenFOAM Running, Solving & CFD 1 July 25, 2009 12:27
Fan heater model: what turbulence source to use? andy20 CFX 7 March 3, 2008 17:42
Problem calculate Y in compressible turbulence model luca OpenFOAM Running, Solving & CFD 5 June 1, 2006 06:53
