Extracting data.
Old   August 16, 2005, 10:22
Default Extracting data.
Sham
Hello all,
I can plot a presuure coefficient over the wall. But does anyone know how can I extract this data from FLUENT so that I can export to excel. I did not monitor the pressure when I am running the simulation.
Thanks.
Sham.
Old   August 16, 2005, 11:37
Default Re: Extracting data.
pUl|
Use the 'Write' option in the XY-PLOT dialog.
Old   August 16, 2005, 11:39
Jason
If you go to Plot->X-Y Plots you can "write to file". What I've done before is write a file for the x-coordinate, one for the y-coordinate, and one for the z-coordinate. Then I pull them into the same worksheet within excel. I think you can also export the data as a comma deliminated ASCII file (File->Export) and that should give you the three coordinates as well as any of the variables you select in the list.
This will only work for the current data file (if it's an unsteady solution, you won't be able to get previous time steps unless you saved the data file).
Hope this helps, and good luck, Jason
[OpenFOAM] extracting data from paraview tharem ParaView 1 January 18, 2011 00:45
extracting data in tecplot peter FLUENT 0 September 24, 2008 12:11
Extracting Post Data to a Text File Ram CFX 3 March 3, 2006 07:20
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
Extracting Stream Function from nodal u,v data Abhijit Tilak Main CFD Forum 5 March 8, 2004 17:13
