monitoring dynamic heat flux through a surface
Old   August 15, 2005, 10:57
Default monitoring dynamic heat flux through a surface
abdnakhi
I am trying to monitor dynamic heat flux through a slab on ground. My domain is completely solid and I am only concerned with heat conduction. I am using [solve > monitors > surface] to monitor the variable (i. e, heat flux through a surface at the end of each time step).
The problem is that after some time steps I print heat flux by means of: 1. [report > fluxes] 2. [report > surface integrals] Flux values provided by these two facilities are identical, but they are not equal to that provided and recorded by [solve > monitors > surface] facility.
Do you know why this is occuring ? can you suggest an approach to record heat flux through a surface at the end of each time step ?
Many thanks in advance,
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
Heterogeneous heat flux Kev STAR-CD 4 July 7, 2009 05:48
Heat flux in ansys cfx juliom OpenFOAM Running, Solving & CFD 2 April 14, 2009 15:30
Applying Heat Flux out of the surface in CFX Ijaz CFX 3 February 26, 2009 17:33
