Pressure distribution
Old   August 14, 2005, 20:16
Default Pressure distribution
Sham
Hello all,
I am modelling an external flow over a cylinder. Is it possible to plot a pressure distribution around the cylinder wall in FLUENT? If so, how?
Thanks in advance.
Sham.
Old   August 15, 2005, 18:03
Default Re: Pressure distribution
Ben
In the plot option you can select pressure and for the surface, you select the cylinder surface. That will give you the pressure distribution over the cylinder.
Old   August 17, 2005, 00:54
ayyappan
hi its better to compare nondimensional pressure than merely pressure
Old   August 23, 2005, 02:16
Allan Cross
The best way I found of doing a pressure plot on a cylinder is with the "Solve--> execute command" and run it every like 10 time steps. the command I'm using is
plot plot yes "pressure%i" yes no no pressure yes 1 0 (1 8) | | | | | | | | | | | | menu | node values | order pt| | cell function | surface ids
command File%i iteration |Y axis Lenght | | iy
Yaxis | ix
X axis
Just get you surface id for what you want, its a pain in the to find these ids i remeber.
Also split you cylinder into the top half and bottom half as you want to have pressure plots each seperate, otherwise you get two pressures for one point in the x-direction. eg, (1 8) 1 is top surface id, 8 is bottom surface id
Airfoil pressure distribution kanishkpanchal Main CFD Forum 2 December 7, 2009 14:21
Pressure Rise Error emueller CFX 0 May 5, 2009 12:08
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
