User Defined Real Gas Model
Old   August 13, 2005, 04:46
Default User Defined Real Gas Model
john
I need to model natural gas in a high pressure (6000kPa) pipeline. I believe that I need a user defined real gas model to do this.
I am looking for code for such a model. It can be Peng-Robinson Equation of State or Redlich-Kwong EOS or similar.
If anyone has this udf, or knows where I can get one from, I will appreciate it a lot.
A UDRGM for methane would be just as helpful. Actually, a UDRGM for any gas will be great. I can always modify it for my needs.
Thank you all in advance.
Old   October 25, 2012, 15:05
Abhijeet Shrawage
ashrawage is on a distinguished road
these equations are available in the material properties of fluent..
just check under density and you will find Peng Robinson equation of state..
All the best...
ashrawage is offline   Reply With Quote
User Defined Turbulence Model Iaroslav FLUENT 1 July 19, 2017 13:22
Question about Real gas model for refrigerant in Fluent ddqp FLUENT 0 March 21, 2011 22:38
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 01:49
Wall Treatment of User defined Turbulence Model Yang Chung FLUENT 0 August 23, 2008 12:31
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
