August 13, 2005, 04:18 |
help in burner problem
hellow,
i have carried out the simple burner analysis. i am getting satisfactory results in laminar and turbulant flow. i have given air velocity as 10 m/sec and temp of 300 Kand fuel velocity as 2.5 m/sec. and temp of 500 K ..in the initialization i have selected all zones and velocity as 5 m/sec and temperature as 2000 K. my problem is when energy is kept on then solution converges but in post processing the temperature of air in, fuel in and burner body all is taken as 2000 K. whatever temperature i give in the intialization that is taken and ignition doesnot take place. please give your suggestion to solve my problem. thanks a lot. sonali |
August 13, 2005, 05:44 |
Re: help in burner problem
well you have not mentioned what combustion model you are using.
i guess you are workign with EDC or some model where you solve for all the equations, try smaller underrelaxation. or try gettign intial solution with flamelet model and the iterate further with this model. |
August 13, 2005, 12:44 |
Hi Sonali,
Initialize the flow using a high temperature and non-zero fuel content, this will allow the combustion reaction to begin. "The initial condition acts as a numerical spark" to ignite the fuel-air mixture. This initialization is especially critical when you include finite-rate kinetics in the overall reaction rate. Regards Saurav |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 08:27 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 09:39 |
Problem with Non-Premixed model (coal burner) | Nando | FLUENT | 0 | June 4, 2007 11:44 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
