Can Fluent 32bit version run using 64bit CPU?
Old   August 10, 2005, 08:02
Default Can Fluent 32bit version run using 64bit CPU?
Danny
Dear Fluent users:
Does anyone know if a 32bit FLUENT version (for Windows XP 32bit version) can run under a combination of Windows XP 64bit version with 64bit Intel CPU?
Thank you in advance,
Danny.
Old   August 10, 2005, 13:16
Default Re: Can Fluent 32bit version run using 64bit CPU?
Vinod Dhiman
Hi Danny
I have tried it with AMD 64-Bit, WinXP as OS, and it works fine. So, it should work with Intel, too.
Vinod Dhiman
Old   August 10, 2005, 16:14
pUl|
You might face problems when loading your UDFs. As they will compile fine but probably into 64 bit libraries by default. Make sure that compilation flags in the Makefile are set to 32 bit.
Old   August 16, 2005, 10:04
Danny
Hello Again,
Thanks for your input.
Anyway, I've asked Fluent the same question and their answers were a bit different. They do not support the use of 32bit Fluent 6.2 version on a 64bit CPU running Windows XP. Therefore they cannot assure us the credibility of the simulation results … Be noted …
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 12:57
A computer to run Fluent - 64 bit? Mike FLUENT 3 September 23, 2005 11:27
UDF in parallel version of fluent yobee FLUENT 2 August 5, 2004 01:36
udf application in student version of fluent arun FLUENT 1 April 8, 2004 21:15
Fluent Parallel/Serial version..jump in residuals Sandeep Abhyankar FLUENT 4 January 10, 2000 10:57
