sloshing in tank
Old   August 10, 2005, 06:38
Default sloshing in tank
manoj kumar
Hi
I am working on a sloshing problem in a tank. There is a rectangular domain (corresponding to cross-section of the tank) bounded by walls from all four sides and inside consisting of air and water. The tank is supposed to roll to-and-fro. How do I impose this to-and-fro oscillation ?
Thanks in advance
Manoj
Old   August 10, 2005, 19:04
Default Re: sloshing in tank
Laika
UDF controlled gravity direction vector
good luck,
Laika, still orbiting
Old   August 11, 2005, 06:57
manoj kumar
Thanks Laika
Can it also be simulated by adding suitable source term in the momentum equation ?
Manoj
Old   August 11, 2005, 08:13
edi
Hi manoj,
I personally found out that the more robust way to deal with time dependant accelerations' fields is to change the gravity components in the operating conditions panel via udf or scheme file as Laika suggested. In case of spinning tanks or other rotations you can use the MRF. take care to set your walls as moving walls with zero velocity with respect to the neighbouring cells.
Cheers
Edi.
Old   August 12, 2005, 15:25
manoj kumar
Hi Edi
Which define macro should I use to define my udf ? Can you send me any such udf?
Thanks
Manoj
Old   August 22, 2005, 04:06
edi
I tried to send it to your e-mail address but received delivery errors. check your e-mail and let me know.
Edi.
Old   November 30, 2009, 20:08
Saeed Abbasi
sabbasi_mr is on a distinguished road
I have the same problem. May I ask you to send me too? Sabbasi_mr@yahoo.com
sabbasi_mr is offline   Reply With Quote
Old   July 30, 2011, 06:53
vipul
vipul is on a distinguished road
Originally Posted by Laika
;123227
good luck,
Hello, i am also solving similar sloshing problem. circular tank under seismic load i have acc. vs frequency(example frequency converted in time period (5 sec. i have acc. value for that time period now i have to divide time period in 4 intervals of 1.25 each and simulteniously changing the direction of acceleration to simulate motion similar to to and fro motion) values i am loking for pressure on all walls due to seismic effect.I also want suggestion to solve it with dynamic mesh or with playing with acceleration values in operation conditons.
vipul is offline   Reply With Quote
Acoustic modeling of Fuel Tank sloshing in Star CCM+ 4.06 joy STAR-CCM+ 1 January 3, 2013 09:42
inhomogeneous tank sloshing overflow error enghamed CFX 1 August 2, 2012 09:42
tank sloshing - getting wrong pressure enghamed CFX 2 April 26, 2011 23:09
Tank sloshing in fluent diverging...need help lostin4ever FLUENT 4 February 24, 2010 08:20
Tank sloshing in fluent diverging...need help lostin4ever Main CFD Forum 0 November 11, 2009 05:26
