Gambit startup error: libXp.so.6 cannot be found
Old   August 9, 2005, 15:39
Default Gambit startup error: libXp.so.6 cannot be found
Patrice Guay
I installed Gambit on an AMD64 machine with RHEL4. When I try to launch Gambit, I receive this message:
> [joe@localhost ~]# LANG=C gambit
: This product has the following patch(es) applied:
: patch_2230_1
: Starting /usr/local/Fluent.Inc/gambit2.2.30/lnamd64/gambit ...
: /usr/local/Fluent.Inc/gambit2.2.30/lnamd64/gambit: error while loading shared libraries: libXp.so.6: cannot open shared object file: No such file or directory
However, the file libXp.so.6 is already installed (xorg-x11-deprecated-libs-6.8.2-1.EL.13.6) and available at: /usr/X11R6/lib64/libXp.so.6 What is wrong? -- Patrice Guay
Old   August 10, 2005, 03:37
Default Re: Gambit startup error: libXp.so.6 cannot be fou
Vinod Dhiman
Hi
I hope you have root privilege. Open /etc/ld.so.conf and add the path of this file, just the path, not the file name, and then save the file. Now run command ldconfig. You can run this command from anywhere. Just type ldconfig and press enter.
Do let me know whatever result you get
Vinod Dhiman
Old   August 10, 2005, 12:23
Patrice Guay
Here is the content of /etc/ld.so.conf:
/usr/lib64/nvidia include ld.so.conf.d/*.conf /usr/X11R6/lib /usr/X11R6/lib64
The last line already contains the path to libXp.so.6. I ran ldconfig, then gambit and got the same error. Where should I look to solve this issue?
Patrice Guay
Old   August 10, 2005, 12:58
Vinod Dhiman
As much as I know, that should have solved the problem. Check whether that file is a file itself, or a link to another file. Although, that should not affect, yet you can try. Its needed to be asked from an OS expert.
I'm sorry, if that doesn't help much.
Vinod Dhiman
Old   August 10, 2005, 13:38
Patrice Guay
I've got it! Here is the answer I got from a Fluent representative:
>since gambit is a 32bit code, the 32bit XFree86 libraries should be
:installed on this system. Gambit will look for libXp.so.6 (and other libraries) in
:/usr/X11R6/lib -- not in /usr/X11R6/lib64
So, I manually downloaded and installed the i386 package named: xorg-x11-deprecated-libs. Now it works.
Patrice Guay
Old   August 10, 2005, 14:03
Vinod Dhiman
That's good. It will be of help in the future if someone else gets the same problem. I didn't observe that the directory I have is lib while yours one was lib64
Vinod Dhiman
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
Gambit Startup surajsunny10 ANSYS Meshing & Geometry 0 May 24, 2010 13:04
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 12:09
