Wing tip vortices using Fluent
Old   August 9, 2005, 06:22
Default Wing tip vortices using Fluent
Jainy
Hi !
I am currently using Fluent (and Gridgen) to try to capture the wingtip vortices properly. I was wondering if you have any tips, references, or even websites concerning this study and particularly the choice of the turbulence model (am using Spalart but wish to try RSM, unfortunately this one does not want to converge).
Old   August 9, 2005, 14:06
Default Re: Wing tip vortices using Fluent
razvan
A study made some time ago (I don't quite remember where I read this), revealed that increddibly, between S-A, Rke, SST-kw and RSM, for this problem you should always choose S-A or RSM. Rke and SST-kw were found to give much poorer results than the other 2. S-A was quite very close to RSM and both to experimental results.
Of course that S-A is much easier to converge, also because when your tip vortex will be shedding, RSM will very improbably be able to obtain a stationary solution and you will be forced to do a transient calculation. This is maybe the most common reason for difficult convergence with RSM (but people generally do not understand that RSM is sometimes too much physics for a stationary solution).
And another "tip": do not make a very dense mesh but rather adapt it by the gradient of pressure (you'll have to play a little with the limits) to capture the vortex path and the results will be more than satisfactory.
Best whishes, Razvan
Old   August 10, 2005, 07:38
hanieh
Old   August 22, 2005, 20:13
helper
There's a AIAA paper authored by the folks at Fluent Inc. Kim and Shin on the very same problem you described. Google it!
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
Wing Aerodynamics Fluent OF 15 comparison maddalena OpenFOAM Running, Solving & CFD 85 August 20, 2013 11:36
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
multi wing element - negative coefficient of drag? Zweeper FLUENT 10 March 11, 2010 13:20
